Serpentine Belt Kit For M-25 - Any Interest?
Maine Sail
Hi All,
I am working with a company called Electromaax to try and source a serpentine belt kit for a Universal M-25 diesel. Electromaax builds high quality heavy duty alternators, wind gens and water makers and also has serpentine kits for many engines, but as of yet, not the M-25 or M-25 XPB.
This kit would drastically limit belt dusting and allow significantly larger alts for those with banks that can take the current, like AGM or GEL battery owners.
As many of you M-25 owners know the factory belt is really limited to 80-85 +/- amps due to the belt size and with a serpentine kit an alt of 160 amps or more is possible. If you have AGM's or a large bank of wets this means a LOT less engine run time to replenish the Ah's used. Even a bank of four flooded T-105's can take more current than you can produce with the stock belt on an M-25.
Electromaax is willing to manufacture this kit, though they are not completely in-expensive, but they are looking for feedback as to who might want one before spending the time to design them and manufacture them..
If you have interest in a serpentine kit for an M-25 please email John at:
jstevens AT electromaax DOT com
Just a note on the Electromaax company, I got the alternator on our last boat from them. John is a stand up guy, he went way above and beyond to get a case on the alternator that would work with our application. Glad to hear he is looking at Universals for his serpentine kits, I knew he was making them for Yanmars, I'd be interested in a conversion kit for our M35A but there's probably not as many of them around as there are 25XPs. But they are similar...
Bud I to would be I interested in one for a m35a. Could you contact him or would Maine sail.
Randy
Randy, I'll try to get a hold of him when I get home. We're out on the boat right now.
General question about the serpentine belt kits. Are they a wider belt, eg., something like the belt on my car? Flat and maybe 3/4" wide? I'd assume that would require changing the crankshaft and water pump pulleys.
I'd also be interested in one for the M35A.
Gary, yes they are the flat multi grooved belt as used now on automotive applications. I'll add one more to the interested list when I call him.
