Riding Sail
10 posts / 0 new
hilbre
Riding Sail
[QUOTE=StillaThrill;6642]Just heard from the sail maker and he still has two sails left at this bargain price. Please contact me for any questions or contact information for the sailmaker.
Fair Winds with a new 150% Genoa,[/QUOTE]
Ralph:
I see what looks like a riding or anchor sail in your thumbnail. How well has this worked for you?
John Meyer
Hilbre 2135
John Meyer
Hilbre
C36 MKll, Hull 2135
StillaThrill
John,
It has worked very well for me. I use the main halyard to raise it up the backstay. It's on a Mark I so, I didn't have to worry about the split back stay. It is the large kit riding sail from Sail Rite that the Admiral and I put together. It's heavy enough that it will last for years and handle high winds , ~25mph. For lake sailing it works great because there are times that we have shallow anchorages and limited room to swing.
Here's a link to a larger picture: [URL="http://www.flickr.com/photos/c36fleet15/2946205904/in/photostream(link is external)"]http://www.flickr.com/photos/c36fleet15/2946205904/in/photostream[/URL](link is external)
The picture is from one of Fleet 15 overnight anchor off the island gathering.
let me know if you have additional questions.
Ralph
Still a Thrill # 765
WK, STD Rig
Lake Texoma, TX
hilbre
Ralph:
Thanks for the information and the picture. I will look into it and figure out how to handle one with the split backstay. I am sure there is an easy solution, I just have to think on it for a while. I have the sailrite catalog in front of me.
John Meyer
Hilbre :D2135
John Meyer
Hilbre
C36 MKll, Hull 2135
bakerha's picture
bakerha
John - when you figure it out - please share your knowledge. I'm looking into a riding sail for next year and also have the split backstay.
_____________
Harold Baker
S/V Lucky Duck
1989 C-36 mkI TR/WK M25XP
What's the forward corner (called a 'tack' or a 'clew'?) tied to?
StillaThrill
The forward point of the riding sail (tack) has a long line on it and I take it forward and tie it to one of the starboard shrouds. I've also tied it to a cleat on the starboard side of the mast.
Ralph
WK, STD Rig
Lake Texoma, TX
John and Harold,
I don't think it matters if you have a split backstay or not. A riding sail should work with either. Simply hank the sail on one side of the split, and hoist it up with the main halyard. I also tie mine off to a cleat on the side of the mast. Since the cleat is a fixed point, I use halyard and tack pennant length to adjust the height of the sail, to make it as flat as possible. I don't want the foot or leach to be too tight or too loose.
Ralph,
I THINK the forward part of the riding sail is called the clew. The only reason I would know is that the sailmaker that made mine (as a peace offering for delivering a sail two months after a promised date) said he attached a long piece of webbing to the tack of the sail, to be tied to the pushpit or backstay turnbuckle. When I looked at him with an obviously blank stare on my face, he explained that the parts of the riding sail have the same names as a regular sail, only rigged as if the boat was sailing backwards. The head is still the head, the tack is still the tack, the clew is still the clew.
Rob Kyles's picture
Rob Kyles
S.V. Wind Star
jackfstewart's picture
jackfstewart
John, I have the split backstay and have used the large Sailrite anchor riding sail for 5 seasons. Use the main halyard to hoist and tie the tack around the mast.
I found it decreased the swinging angle at anchor in half. Even had it up during a 60 mph blow in the North Channel last July.
Heading north now going up the Michigan coast of Lake Huron. Be in Cheboygan Monday.
Jack F Stewart
1993 C36 #1233 "Windancer"
Port Clinton, OH
StillaThrill
[QUOTE=TomSoko;9190]
Ralph,
I THINK the forward part of the riding sail is called the clew. The only reason I would know is that the sailmaker that made mine (as a peace offering for delivering a sail two months after a promised date) said he attached a long piece of webbing to the tack of the sail, to be tied to the pushpit or backstay turnbuckle. When I looked at him with an obviously blank stare on my face, he explained that the parts of the riding sail have the same names as a regular sail, only rigged as if the boat was sailing backwards. The head is still the head, the tack is still the tack, the clew is still the clew.[/QUOTE]
Tom, Thanks for the clarification about the clew/tack. Your explanation makes perfect sense.
Ralph
WK, STD Rig
Lake Texoma, TX
