Engine exhaust Black under load
richie30's picture
richie30
The exhaust coming from the back of the boat has alot of black in it. It was always there under load, but seems to be getting worse. Just pulling away from the dock now causes it.
A local diesel tech, told me it is likely the injectors....about a 700.00 job, but said this may not be the problem!
Any thoughts?
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
Is it black all the time or just when you're increasing the power as you leave the dock? The latter is fairly normal, the former is not.
bboggs's picture
bboggs
My limited understanding is that black smoke indicates incomplete combustion. As you've been told, worn injectors that allow unatomized fuel to drip in the cylinders before the injector fires is a common cause. You might try checking that the airfilter is clean and un-obstructed before resorting to replacing/rebuilding the injectors.
I did have rebuilt injectors on my previous boat with good results.
Bill Boggs
s/v Palmetto Moon
1991 C36, Hull 1128
Herrington Harbor South
richie30's picture
richie30
Appreciate your help! Thanks
Rich
Richard & Joan Bain
PAZZO Hull#1670
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
