Don't think this is worthy of a tech article but thought it might be good to post my experience with how much material we used to finish the bottom this spring. Last fall I sanded all the VC17 off and this spring? (? worst ever spring to do work on a boat up here) did the barrier coat and anti fouling.
I used Interprotect 2000E and, by their online calculator which does a length * beam * a factor they use for sailboats, to get 5 coats I would need 8 gallons of product. I actually ended up using less than a gallon per coat, the first coat used the most at about .85 of a gallon, subsequent coats less and less as the thickness built. I was putting it on as thick as I dared, I found when I tested it last fall this stuff will not set up if it's too thick, it just turns to a rubbery yutz. We easily got the recommended 10 mil thickness using a 3/16" nap roller cover. They said to use a 3/8" nap but I saw a boat that was done with that nap and it was a very rough pebbly surface. Ours turned out pretty fair, not as slick as VC17 but still pretty decent.
We had bought both white and gray to alternate coats and make sure there were no thin or missed spots but the chandlery hosed us, one kit marked Gray was actually White. That particular day I had only brought that 1 kit with me, the boat is 2 hours from home, and there is no chandlery anywhere near our boat so I had to use it. You have to really watch your coverage when not using contrasting colors, Suzanne followed me as I rolled to make sure we missed nothing. It only used to be available in grey which must have made it difficult to ensure good coverage. The alternating colors are definitely the way to go.
For the antifouling I used Petit Horizons, their online calculator said I would need 3 gallons to get 3 coats. Put a base coat of black on and it used slightly more than half a gallon. The next coat was blue which I found a lot brighter than I wanted, so for the last coat I mixed the remaining half gallon of black with 1.5 gallons of blue and got a nice deep blue out of it. I have about 1.4 gallons of paint left over. The last coat went on yesterday.
Tuesday is the first launch day at our marina so while the crane is there we are lifting the boat forward on the cradle so I can repeat this work were the 7 pads for the cradle are. It has been a very tough year to get this done, very cold wet spring. We're supposed to launch May 8th but there's no way I'll have it done by then, weather forecast shows more rain and even if every day was perfect I'd be hard pressed to get it done in time. Fortunately, there are a couple of wood boat guys who won't be ready in time either so we're bringing the crane back in for a 3rd lift later in the month.
We took the winter tarp off yesterday and it was so nice to see the boat again. Suzanne made a whole new dodger and side windows and replaced the bimini top over the winter and we finished fitting it to the existing enclosure panels. She looks great with the new bottom paint and we continually get people commenting on what a pretty boat it is. These have to be one of the most graceful boats ever designed, IMHO.
Bottom line on this is that as we have found with calculators for house paint, they like to sell product. But it's better to have too much than too little.
Bud,
I am curious as to why you did not stay with VC-17. I find it so easy to apply that I cannot imagine changing. About five years ago I found three small blisters and was concerned, but have not had any since. (Knock on teak)
Richard
1994 C36 Tall Rig M1.5
Waukegan Harbor
Lake Michigan
Richard, we are planning on going south for a year so needed to change to something suitable for both salt and fresh water. If it weren't for that I probably would have stayed with VC17, taking bottom paint off is a lot of work and putting the new stuff on is proving just as difficult. A little help from the weather would have made it easier.
We didn't really need to do the barrier coat since the Mk II's have vinylester gelcoat and it's unlikely to blister but taking the old paint off will thin the gelcoat and that's not good. Plus everyone said I was crazy not to barrier coat it while it was bare, it's just cheap insurance. Not doing it would have saved 5 coats but it seemed a no brainer to do it.
Having changed I look forward to some of the advantages of the soft ablative, mainly eliminating the need for annual bottom painting. With this stuff you just touch up the areas were the next layer is showing through. A friend has this on his 36' trawler and he uses less than a quart a year for touch up. There is also no build up due to its self polishing nature.
The VC17 is definitely a slicker surface though, no question about that.
Hey Bud I know what you went through as you know we did the same thing prior to the year we took off and went to the Bahama's. Well we were hauled on Saturday the 30th and Green Cove Springs marina was surprised how clean our bottom was for being in 11 months. We used Micron Extra from Interlux and was very pleased with it. What is interesting is that I called and talked to Interlux about what paint to use and if I had to strip the vc17 off and I was told yes. Well there is a boat from Lake Erie that hauled out the day before I did and he has on the same paint and all he did was ruff up his vc17 and put on the same paint as I have. I asked if he talked to Interlux and he said yes he did and was told all he had to do was ruff it up. If I would have known that it would have saved me a lot of time. But it is behind me now and a lesson learned. All I need now is a quart for touch up but I need to straighten out my water line as I have one of the Catalina with a messed up water line form the factory. One thing I did though was scrubbed the bottom usually every 2 months while out snorkeling. It will not be long and you will be in warm weather. Randy
