Lewmar ports - model and size
In a prior thread on hatch/portlight crazing, I found a link to Select Plastics. They have parts for Lewmar ports and hatches including the O-ring seals I need for the latches on my ports.
[url]http://www.selectplastics.com/index.php?page=shop.browse&category_id=2&o...
The parts are by model and size. I don't have my manual at home, but I believe the models on the market at that time were Lewmar Ocean or Rollstop ??? Any idea on the size of the ports.? The seals are organized by size 0-30 and 40-65. I'm thinking they are probably 40's, but not sure of that.
If anyone knows, I'd appreciate the info.
Thanks.
dejavu's picture
dejavu
I have a Mk I, so I'm no help. But, if you call Select Plastics and ask for Tony, the very friendly owner, I'll bet he knows.
Thanks, I just may do that. Probably the best way to ensure I get what I need.
nelson
I'm not sure what hatch you are referring to. If it is the opening hatch in the v-berth, it is likely an Ocean 65, which has a trapezoidal shape. Catalina Direct sells a replacement lens:
[url]http://catalinadirect.com/index.cfm?fuseaction=product.display&product_I...
--Nelson
Fortunately, at the moment, the forward hatch is in just about perfect shape, no crazing, no leaks. It's the port size/model I need to get the seals for the latches. I do need to replace the lenses in the rectangular hatches on either side of the companionway, then the hatch lens over the dinette.
First priority are the leaking port latches, which I've been fooling with on and off for years :mad:.
Turns out Catalina Direct has a hatch dog seal kit. Just what I needed..!!!
[url]http://www.catalinadirect.com/index.cfm?fuseaction=product.display&produ...
