Maybe I do not know how to search for this, but...
The little handle on the muffler drain valve has broken off (rust). Can this part be replaced or do I have to replace the entire muffler? I am pretty sure this is the original muffler system that came with my boat.
Jeff
S/V Wind Ensemble
1987 C-36 Wing Keel
Universal M25XP 23hp
Hull #705
Coastal Alabama
Jeff,
Mine does not have a petcock or valve, it just has a drain plug. I believe it is 1/4 pipe. You should be able to find a replacement valve at most hardware stores, they are usually sold as a gas valve and are brass. You could also use just solid threaded plug.
Try the Catalina Direct web site, I think they have a replacement petcock valve.
Thanks. Found it on Catalina Direct.
Jeff
S/V Wind Ensemble
1987 C-36 Wing Keel
Hull #705
Coastal Alabama
The plug method works too. About a year ago, on a day planned for a sail, I had to drain the aqualift muffler. The original petcock came apart.
NOT to be deterred from a great day of sailing, I took a quick trip to WM and bought the correct adapter and plug, since a replacement petcock was not available.
Went sailing after making a quick repair! Didn't even require any duct tape :).
Laura Olsen
Past Commodore
S/V Miramar
Edgemere, MD
Thanks, Laura. When you say "correct adaptor and plug", can you be more specific?
S/V Wind Ensemble
1987 C-36 Wing Keel
Hull #705
Coastal Alabama
The muffler has a threaded hole that houses the original petcock device. It is a one piece unit, so when the wing nut part broke off, it no longer allowed me to turn it open to let water out.
I was able to unscrew the entire one piece fitting (broken petcock and all) and take it to West Marine to match for size (outer diameter).
I purchased a brass fitting of the correct outer diameter and that exactly screwed into the original hole in the muffler. The fitting has a threaded hole in it. Read on.
I also bought a smaller plug fitting that screws into the hole in the new brass fitting. When I need to drain water, I unscrew the smaller plug, while leaving the larger fitting still securely screwed into the muffler. You just have to use a little care to loosen and remove the small on without allowing the other piece to come out too. Even if it did, it is just water and is not a pressurized system, so there is no big deal.
I cannot recall the exact sizes, but if you have the old one, you just measure and match. IF I can find my receipt, I can tell you the sizes.
Laura Olsen
Past Commodore
S/V Miramar
Edgemere, MD
No need to go to the trouble to find the receipts, Laura. I just wanted to make sure I understood what you did. Thanks for the input/advice. Sounds simple enough.
Jeff
S/V Wind Ensemble
1987 C-36 Wing Keel
Hull #705
Coastal Alabama
