Sail Cleaning
Mary Wanna
Sail Cleaning
I am haveing my sails cleaned. Has anybody had McLube sailcote applied to there sails and if so how did you like it.
robert rappold
Isn't McLube SailKote a lubricant? I use it when I put the genny up to lube the furler slot. It makes that job much easier. Never heard of it being applied to sails other than that but then again I learn something new every day.
[url]http://www.mclubemarine.com/sailkote/[/url]
Interestly, I would have agreed with Bud, but a little research on the site yields this:
TEAM MCLUBE SAIL APPLICATION GUIDE:
The benefits of coating spinnakers with Sailkote are listed below:
• Minimize water absorption to keep spinnaker as light as possible at all times
• Minimize friction when hoisting, dousing (and gybing assym) spinnakers
• Maximize resistance to tearing cloth on sharp objects
• Minimize possibility of mildew
The benefits of coating genoas with Sailkote are listed below:
• Minimize friction when tacking (overlapping genoa against mast and shrouds) this friction is the main cause of the breakdown of the genoa cloth and laminates.
• Minimize water absorption to keep genoas as light as possible at all times.
• By coating luff tape (or hanks) of sail, friction is dramatically reduced when hoisting. For maximum benefit during peel changes, be sure to coat both sides of genoa entirely.
• Maximize resistance to tearing cloth or laminate on spreader tips and sharp objects.
• Keep telltales sensitive and flying in wet conditions.
(plus much more - Duane)
Nimue's picture
Nimue
Common practice to do this to the spinnakers on small one-design boats. Consensus seems to be it is worthwhile on stuff like 49ers where the spinnaker spends a lot of time in the water, lesson a keelboat where it is typically not dunked in the ocean. Also lots of people think it shortens the life of the sail a bit overall.
Even the Melges 32 I sail on doesn't use it, although that boat probably should. On my Catalina? Nope.
There it is, learned something new again today. I bet you would use a lot of cans of this stuff up spraying a spinnaker!
Nimue's picture
Nimue
A little squirt on the tell-tales on the genoa before it rains can be pretty helpful in keeping them working though...
Mary Wanna
Thanks for the input. I think I'll nix the idea of having the sails done. Thanks All
robert rappold
jsc4484's picture
jsc4484
I hope she lets us knwo the outcome of this. I would be really like to know if it works, I use ite on alot of gear aboard, but never sails.
FAIR WINDS & FOLLOWING SEAS
Jeff Costa
S/V KAIROS Hull #0235
