First (of many questions)
11 posts / 0 new
MazeRat7's picture
MazeRat7
So, this is our first weekend on our "new to us" C36 Tall. It's about 32F outside and very comfortable inside with all systems working as expected except the stove/oven.
The top burners are working great provided you light them. This is a GSI unit that I assume was orig. equipment. It uses CNG but the oven has issues. I did get the pilot on the oven to light but after several minutes, there was liquid mercury dripping down the lines that lead to the oven to the bottom of the oven below the burner. While the pilot light works, the burner will not fire.
So what is going on here ? Advise please.
Cheers,
MZr7
1985 Catalina 36 Tall #404
s/v Peace of Mind
Austin, Tx.
chs1517's picture
chs1517
MZr7,
I had a similar problem with my stove, Princess double burner/single oven model. I had no problem getting either of the burners to light but the oven was a different problem.
I got on the net and went to the Seaward site. It had section to identify your stove and it's valve setup (good pictures) as well as a trouble shooting guide for a quick fix or to identify your problem.
After determining my oven valve was not working I contacted Seaward by phone and was told they had had replacement valve/parts for the stove. If I remember right they wanted me to remove my valve and send it to them for a replacement. The reason they want your old valve was for its core. If your valve was usable they would refurbish it and have a valve for future stock. If your valve was rebuildable you got some cash back along with the purchase of you refurbished valve. If it was not rebuildable you paid the full amount. At the time I contaccted them they only a few valves available and I was told sometimes there was a waiting list.
Here's the problem why they only had a few valves in stock. Since the older model stoves are no longer made of course wouldn't you guess the valves are't either. When they were still being made no one thought there would be a demand to save the valves thus the old cores were tossed as scrap. Now they are in demand and not many are around.
After looking at the pros and cons my solution was to bite the bullet and purchase a new stove. The replacement is a perfect fit and the push button igniters are handy. I didn't want to spend the money on a new stove but I really didn't want to spend money for the refurbished valves and have to work on my stove. It was uncharted territory for me and all I needed was to have a stove on board that was either too hot or cold which would frustrate the chef. You know, "Happy wife, happy life!"
Note: I kept my old stove. Now that it's winter I am going to remove the cores and send them them in for their core value... The remainder of the stove will head to the recycle bin... If the cores are usable the money I might get will at least off set the cost of the new stove... :)
Chris
Chris Stewart
S/V "24~7"
1984 Catalina 36 Tall
Hull #251 M25
(SF Bay) Alameda, CA
MZr7,
Can we be less formal, may just I call you MZ?
In answer to your question, your pilot lite heats mercury in a tube that applies pressure to a valve the allows the gas to flow to the burner. It is called a thermocouple and keeps gas from going to the burner if the pilot goes out.
Be careful with the mercury, or you will never get out of the maze, same thing happened to the Mad Hatter.
PS: My thermocouple does not work either.
MazeRat7's picture
MazeRat7
[QUOTE=Steve Frost;3589]MZr7,
[/QUOTE]
Of course, others just call me Maze, and well.. others have different names for me that are not appropriate for a public forum. :)
Good thing to know about the thermal couple. I was heading down the route Chris described and got a bit of sticker shock when seeing the retail price of a replacement 2 burner stove w/oven.
Also, it seems I'm running low on CNG and one of the items mentioned from the survey was my tank test" was out of date. So even if I can replace a part or two and get the whole unit working, I still have to locate a place to get my tank refilled (and possibly tested)
s/v Peace of Mind
Austin, Tx.
Maze,
In the Technical section of the website (under Upgrades) there is an article on how to make a CNG adapter so you can fill your CNG tank from filling stations that cater to fleets (taxi's, etc.). I know this doesn't help with the tank test date, but it sure does help with the cost of CNG refills.
chs1517's picture
chs1517
Maze,
I found the site regarding the valves. Sure has updated its site since my last visit. It seems to have a lot more info than when I was having problems with my stove. I don't know if it will help you out but here's the site...good luck.
[url]http://www.suremarine.com/stove-repair.htm[/url]
Chris
Chris Stewart
S/V "24~7"
Hull #251 M25
wfahey's picture
wfahey
Maze
Welcome to the forums. It is nice to have a fellow C-36 owner in the neighborhood. Do you keep your boat at Travis or down at the coast?
s/v Lucky
1984 MK I Hull #266
San Antonio, Texas
[url]www.safgas.com[/url] has where to refill. Tom already covered the how to make a refill connector link. The stove needs to have the right hand burner hot before you try to light the oven. There should be instrucgtions inside the stove for that.
catalinapilot
The oven on our '00 MKII hasn't worked in years. I took it apart once and cleaned the orifice. It's one of those not very satisfying jobs. It's difficult to work on in place - the galley floor area is not exactly wide open.
It worked for about two weeks and then clogged up again. Any idea what replacement parts cost assuming a valve is bad? Wonder if I would be smarter to just save up for a new unit but then I'd miss the joy of solving this problem - again. Builds character.
Bruce
Southern Comfort #1881
Tall rig, Wing Keel
mablamb
I am not familiar with the issues that Chris discussed regarding cores etc. I had the same problem last year and since we live close to the Seaward factory I stopped in and purchased a completely new valve and replaced it with ease. Only issue was routing the thermocouple down the inside space of the oven wall that is insulated. I used a small wood doul to open the space. Call Seaward and see if they have the valve assembly, it was $100. The tech at Seaward said that the reason they fail is not that they are overworked but just the opposite - he said to light the oven and excersize the valve on a regular basis and that would prolong life. The mercury is as previously stated from the inside of the cooper TC- mine broke while removing the old one and dripped some mercury in the oven. I forwent a complete haz-mat remediation with a paper towel. Don't tell any one. Call them at (562) 699-7997, [url]www.seawardproducts.com[/url]
The valve replaced is the one that has that has the thermocouple running to the pilot light, not the one that the knob attaches to. It also has a TC that runs to the cooking space on the back wall of the oven. The Sure Marine site has good pictures and documentation of the various parts. It seems that the core issue may relate to SureMarine and not Seaward. If I recall, Seaward took my core but did not ask for it as a prerequisit to me purcashing the new one.
Good luck, Mark
Mark Bierei
Fleet 2 Long Beach
1985 C36 MK1 #456
Wing N' Prayer
MazeRat7's picture
MazeRat7
[QUOTE=wfahey;3607]Maze
Bill[/QUOTE]
Hey Bill, pleasure to meet you. I'm on Travis @ Yacht Harbor (now called Sail and Ski Marina in Lakeway).
If your ever up this way, I would really love to have some advice from a seasoned C36 owner on my new girl. Would love to have you and yours aboard for a day sail.
Peace,
MZr7
s/v Peace of Mind
Austin, Tx.
