Hot Water Tank Leak
richie30's picture
richie30
Hot Water Tank Leak
I have a good suspicion that my phantom leak may be from the hot water tank. This is on our 1998 fresh water low hours boat. Hull # 1670.
Has anyone encountered this problem, and is replacement a tough job? I assume the air / heat pump would have to come out, if that is how best to remove it.
richard
PAZZO 1670
Bayfield, ON Canada
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
Jimmy's picture
Jimmy
Check the hose connects under the cushion. The hot side needs to be replace every couple of years. Also, check the anti-freese line under the sink if you see pink water. They may need to be tightened. You'll have to take the entire draw assembly out to get to them.
Jim
Jimmy,
Secondwind
Hull No. 2058
dwarburton
Richard,
I would also advise looking for the simple solution first. There are about 100 hose clamps in that area, all it takes is one loose one to cause a leak. Also, It is hard to tell exactly where the leak is coming from in that area.
A few thoughts:
Does the water pump cycle occasionally (usually in the middle of the night) when all faucets are off? If it does, the leak is on the high pressure side of the pump. If it does not, it is on the low pressure side.
The heater drain valve often leaks.
For what it is worth.
Dave
Dave
Ballena 1995 Mk II #1445
Elliott S. Milstein's picture
Elliott S. Milstein
I have had to replace the fittings that go into the tank. While awkward to reach, they are threaded and are available as standard plumbing parts. Two of them developed leaks over time. You can easily see whether water is dripping from them. Another source for leaks for me was at a one-way valve that connects two pieces of tubing together. It keeps water from the heater from flowing back into the water pressure system. The original one on my boat was made of plastic and I replaced it with one made of brass. I have also had to tighten hose clamps. It has always been a relief to discover these inexpensive fixes rather than having to replace the heater itself.
Elliott Milstein
Collaboration #1469
1995 C-36MkII
Port Annapolis Marina
richie30's picture
richie30
Thanks to all!
Rich
Richard & Joan Bain
PAZZO Hull#1670
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
