Temporarily sealing deck holes
benethridge's picture
benethridge
Hi, everyone. This is just an FYI, in case you ever want to do this. Might save you some time:
I'm repairing deck hardware leaks, and after removing the deck hardware, decided to temporarily cover the exterior holes with tape, so that, using my dehumidifier on the interior, I could dry out the deck core (balsa I assume).
I tried three different kinds of tape before I found one that was truly waterproof - waterproof meaning I could drown the tape-covered hole with a water hose and no leaks would show up below, in the interior side of the hole in the deck.
Transparent duct tape found at West Marine - leaked.
Special aluminum covered "waterproof tape" found at Home Depot - leaked probably due to the lack of flexibility on the standard C36 non-skid deck pattern.
Seafit Premium Boat Stripe "Superior UV and Moisture Resistant" tape - found at West Marine - did NOT leak probably due to superior flexibility on the non-skid pattern. Hooray!
Hopefully I can get the tape and its adhesive off easily in a couple of weeks when I get back to finishing the holes. :-)
Ben Ethridge
1984 MK1 Hull# 263
Ciscocat's picture
Ciscocat
hi, FWIW, all the core material on the mark I, at least mine is plywood, which means that any water damage that has been around for awhile has a good chance of migrating to the surrounding area.
Mike Hogan
Ciscocat #226
Mike Hogan
s/v Ciscocat #226
Mark I XP25, std rig
