Anchor Windlass Isolator
nbpatterson's picture
nbpatterson
Hi, I have recently taken ownership of a 2001 C36 MkII and am currently going through the boat sorting things out and making sure everying is working. I live in Sydney, Australia, and am looking forward to sailing on the harbor and offshore.
The windlass was not working and the problem has been tracked down to a circuit breaker which forms part of the battery control panel below the starboard seat. After a bit of fiddling and dismantiling the circuit breaker, I have got it to work, but I would feel happier about replacing it.
I notice it is a Texas Instruments Klixon rated at 135A (the Catalina manual suggest 80A which makes sense as the Maxwell Freedom 800 windlass is rated at 1000W (= 83A).
Does anyone know where I can order a replacement switch from?
Regards,
Nigel Patterson
Nigel Patterson
Sydney, Australia
Fresh Aire II, 2001 C36, Hull # 1976
wfahey's picture
wfahey
Nigel
Congrats on the boat! Here is a link for the Klixon breakers.
[URL="http://www.cmsquick.com/prod_24_K1.html"]http://www.cmsquick.com/prod_24_K1.html[/URL]
s/v Lucky
1984 MK I Hull #266
San Antonio, Texas
nbpatterson
Bill,
Thanks for the link. It seems to have everything on it. Are you aware what the required part number is? If not, I should be able to pull the panel apart again and get it off the switch.
Nigel
Nigel Patterson
Sydney, Australia
wfahey's picture
wfahey
Unfortunately I do not know the part number Nigel.
s/v Lucky
1984 MK I Hull #266
San Antonio, Texas
hwy1cat36's picture
hwy1cat36
Is this the windlass circuit breaker?
http://www.go2marine.com/product/206281F/lewmar-windlass-circuit-breaker...
It looks like the one I have to replace
Gary Johnson
1999 Cat 36 mkii, M35C
​Hull # 1755, Fin Keel
Homeport: Long Beach, California
