Head Faucet and Shower
Rob Hamlin
The head faucet and shower controls on my 1991 C36 need replacing (corroded and flaking). Does anyone know where to get pieces that fit the original holes / plumbing? The shower controls are seperate and mounted on the vertical face of the vanity under (and to the right of) the sink. Thanks.
Spanki's picture
Spanki
Rob, my 93 doesn't have that set up but I've seen it at Defender I think, we replaced ours with a Scandvick we bought through them, it installed and "bolted down" from the top. Good luck!
Satori II
Just went through the very same issue.
We ordered our parts from Catalina Direct and it was a perfect match and a breeze to install.
Jeff Cote
Satori II
Hull #1065
 Jeff Cote
C36, Hull#1065
Moorage: Ucluelet BC
hwy1cat36's picture
hwy1cat36
Spanki, or Jeff, or anyone else,
My head faucet is currently leaking and needs to be replaced after 16 years.  Are you saying the faucet can be removed and replaced from the top?  Other than the hose fittings there is not a nut between the hull and sink under the counter top?  I sure hope so anyway.
Gary Johnson
1999 Cat 36 mkii, M35C
​Hull # 1755, Fin Keel
Homeport: Long Beach, California
