Hello,
We have been told that our rudder bearing and seal washer is loose on our 2010 Catalina 375.  How do we find this bearing and seal washer and how do we go about tightening it?  Any special instructions on this?  We are new to this boat.  Thank you very much.  Jim
rudder bearing and seal washer loose
      Thu, 10/22/2020 - 16:16
    #1
Hi Jim, I've got a 'new to me' 2009 C375 that had a rudder void and wet area that was surveyed when we bought her last fall. We had the rudder dropped and professionally repaired as part of the purchase, but checking out the reinstallation, I was surprised at the room and access to the rudder tube and steering- the top bearing and retaining ring are secured by bolts, at the top of the tube.
If you climb into that huge aft port lazarette, you'll be able to see all of it. There's a decent diagram on the Catalina Direct parts site, look at the replacement bearings page : https://www.catalinadirect.com/shop-by-boat/catalina-350/hull-deck/stern/rudders/rudder-bearing-c-309-c-310-c-350-c-355-c-375-c-380-c-387-c-400-c-42-c-445/
Tom
