How to cleanup a very messy oil leak
9 posts / 0 new
knotdoneyet
Have an oil leak that made a major mess in my engine compartment. When it hit the alternator belt it got slung all over the place.
Anyone have any tips how to make cleaning this a bit easier?
It would be nice if I could get it all dissolved as a liquid in the pan and then extract it with my oil pump.
Interestingly, I lost very little oil. Maybe a cup or so which is amazing for the mess it made!
2000 C36 MKII 1825
newguy's picture
newguy
Dawn dish washing liquid mixed with warm water in a spray bottle works wonders. It's a bit aggressive on gelcoat, so easy does it and make sure you spray everything down with clear water when you're done.
knotdoneyet
That's working well. Any concerns about spraying all that water on the engine?
It does need to be really strong to work well.
2000 C36 MKII 1825
Wait Griswold
Remember to turn off the bilge pump and pump the water into a container for proper disposal.
Wait Griswold
C36, #2109, 2001
Alameda CA
newguy's picture
newguy
The hotter the water, the better. BTW, Dawn is by far the best brand. Not much concerns on spraying around the engine as long as the dipstick is in and the oil filler cap is on tight. Do minimize spraying into the alternator and any electronic gizmo that might be mounted in the engine compartment. Give everything a good chance to dry.
knotdoneyet
Any suggestions for how to get the oil out of the wood at the base of the engine cover? The forward edge has oil soaked in about 1/2" up. It's leaving oil marks when I set it down.
Cosmetically, it is going to have to be covered as the laminate was already chipping off in many parts. I suspect that most have encountered the laminate being pulled off from the bottom from taking the cover off and putting it back.
2000 C36 MKII 1825
One of the best cleaners we discovered a few years ago was Awesome from the dollar store.
FlyMeAway
Great article here about how Dawn really IS the best brand for oil:
[url]http://www.npr.org/templates/story/story.php?storyId=127999735[/url]
Also remember that once you have mixed detergent into your bilge, an oil absorbing pillow / sock will no longer work properly and to keep the environment clean you'll have to dispose of *all* of that wastewater somewhere.
David
s/v Portmanteau
Hull #2133 -- 2003 MKII
Seattle, WA
[QUOTE=KnotDoneYet;21798]Any suggestions for how to get the oil out of the wood at the base of the engine cover? The forward edge has oil soaked in about 1/2" up. It's leaving oil marks when I set it down.
Cosmetically, it is going to have to be covered as the laminate was already chipping off in many parts. I suspect that most have encountered the laminate being pulled off from the bottom from taking the cover off and putting it back.[/QUOTE]
This is a guess; but you might try oil dry (or kitty litter). Oil dry will suck oil out of concrete almost completely. If you set the bottom of the engine cover, which is also porous, it just might pull the oil out. Of course,, you'd have to make a little pile of oil dry the whole way around where the cover will sit; not quite as easy as throwing in an oil spot on the garage floor.:rolleyes:
