Mermaid Heat /Cool System Replacement
richie30's picture
richie30
Has anyone replaced their aging Mermaid with the same model or a different option?
mine is a 1998 unit, is still working, but I'm just planning ahead!
Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
sidthekid's picture
sidthekid
Rich,
The condensation pan on my old Mermaid corroded out and leaked water. Eventually, unit stopped cooling...
The unit was replaced with a Dometic DTG16 Reverse Cycle Heat Pump With Smart Start. This version has a composite pan - no rusting. The control panel also had to be replaced.  After a year, both heating and cooling are very good.
BUT, I was hoping my Honda Generator 2000 series would support powering the Dometic at anchor with the Smart Start. Technician at Dometic stated 40 amps are required for a milli-second, and the 30 amp rated generator will not power the compressor on. If anyone has a work around for this please post.
Bill & Barb
s/v Northern Lights
2002 Catalina 36 MKII #2086
Rock Hall, MD
Northern Chesapeake
richie30's picture
richie30
Thanks for the note, was it quieter than the mermaid? I find the mermaid when it cycle goes on and off through the night can keep us up. Take care, Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
sidthekid's picture
sidthekid
Rich, the new unit is a "bit" quieter. The fan speed can be adjusted as well, but only helps a "bit". Dometic offers a sound insulator cover for some models. But the heat or cool air when needed, more than makes up for the noise of the unit...
https://www.dometic.com/en-us/outdoor/boat/marine-air-conditioners/marin...
Bill & Barb
s/v Northern Lights
Rock Hall, MD
Northern Chesapeake
TippingPoint
Rob,
I assume you are in Ontario,  I was always with the impression that your region was relatively cool.   I never considered AC for my Catalina 36 however if in the islands or keys perhaps yes but then the dilemma would be he Generator, would want a Diesel 3 or 4K watt gen that would have be be very quiet, like you would see in the newer production boats like the Beneteau 46 etc.
Ed Dewsnap
Marion, MA
1984 Catalina
