Re Bed Rigging / Chain Plates
richie30's picture
richie30
I am resealing my deck hardware, in particular the top of the chain plates where the rigging goes through the deck, I purchased from Catalina direct some new hardware for the top side with a collar around it which holds more sealant. My question is should I be using 3M 4200 or 5200? Thanks so much, Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
Absolutely's picture
Absolutely
Definitely not 5200. One would only use that if you never intended to take it apart.
And rather than a caulk product, I highly recommend butyl tape.  It's so easy to work with and does a fantastic job for years, remaining flexible and sticky. Also, when a job does eventually need to be re-done, it's so easy to remove the old butyl tape, unlike a  caulk product.
I am glad you got the upgraded plates from CD. Our boat has them installed all around, also, and I am pleased with them.
Dale and Nikki
1998 C36 mkII SR hailing from Poulsbo, WA
1989 C25 TR/WK
