Last weekend I noticed a few drops of fuel under my Racor filter and when I touched the bottom of the plastic bowl on the water seperator the screw valve broke off. It was cracked and it was going to break off at some point anyway. Lucky I'm working on winter projects and ObLaDi ObLaDa is on the hard. Needless to say it made a mess until I shut off the tank valve. I see Cat Direct is now only selling the so called "improved" aluminum bowl. I still prefer the clear plastic bowl so I can see if there is any water in the fuel. Does anyone know where I can buy just a plastic replacement bowl that will fit a R15T Racor filter? Lots of plastic bowls available on line, but i'm not sure it will fit the Racor filter I use. Anyone know the specific Racor plastic bowl model numbr?
Tom Runiewicz
ObLaDi ObLaDa
Hull #1998
North East, MD
Tom;
Just a recomendation that you purchase and install a complete new Racor fuel filter assenbly (perhaps a type 120) rather than trying to piece together the old one. The suggestion comes as the result of an experience I had last season where the paint on the filter assembly was being broken down by the diesel fuel oil and caused an air leak into the fuel system at a seal point. It took forever to find but Ithink you would be better off with a whole new assembly. Might be less expensive too.
https://www.defender.com/product3.jsp?path=-1|311|2349059|2837510&id=133972
YMMV.
Excellent suggestion Bill. I stll prefer the units with the clear plastic bowl rather than the aluminum ones you can't see into. I'll look around other than CD. They are only selling the aluminum ones now. See Defender has some.
Tom
Tom Runiewicz
ObLaDi ObLaDa
Hull #1998
North East, MD
Tom;
By the time one gets around to buying a new filter and bowl, you are at the price of a brand new Racor Assembly. I replaced my old Racor with the unit indicated below paying around $100.00 + or - with commericial discount at Bacon's in Annapolis. The filter uses a plastic bowl as only Coast Guard inspected boats in commericial service are required to use metal bowls and you can use the old elbow fittings.
The Racor filter coding is as follows; The R-20 'S' filter is filtering at 2 microns; The R-20 'T' is filtering at 10 microns and the R-20 'P' is filtering at 30 microns. Recall that the finer the filter you use, the more pressure is placed upon your fuel pump to get the fuel through the filter. That probably equates to a shorter life for your fuel pump.
I use a R-20 T filter at 10 microns since the fuel filter mounted on the engine is 10 microns and my fuel source is usually reliable. The injectors will usually tolerate 10 microns. Just remember to turn the fuel off at the tank before starting this project. .......Bill
https://www.defender.com/product3.jsp?path=-1|311|2349059|2837510&id=366095
I've used several from eBay like this one. They have all worked just fine and at under $10 hard to beat.
https://www.ebay.com/itm/For-Racor-RK30475-Bowl-Kit-Fuel-Water-Filter-Separator-320R-RAC-01-S3213-S3214/233404298837?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D783b4eef5ed34cd0a9c0841b609ce65b%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D233404298837%26itm%3D233404298837%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3Aa9f36e61-0d4c-11ea-ab77-74dbd18040bd%7Cparentrq%3A9422faed16e0a99c67fa2c08ffe71983%7Ciid%3A1
Having had engine failure while underway, due to tank contamination, low fuel level, and rough seas, I have thought about installing Racor's dual filter kit to allow you to switch over from one filter to another while underway, if need be. Has anyone done this? Is there room?
David S. Power
Two If By Sea #1687
Burnt Store Marina
Not Racors prebuilt dual but much cheaper. I did a write up on this over a year ago. Check the back issues of Mainsheet. (In members only section).
in addition to dual filters I used dual lift pumps, so I can polish fuel if necessary
note Racor 500's do work well but I feel are overkill for our small engines. You need to go thru a bunch of filters to make the high initial price of the unit make up for the lower cost of the consumables.
Les
