Prop shaft grease?
Prop shaft grease?
 I broke two gear pullers trying to remove my three bladed prop that's been on the shaft since new. Heat from a torch did nothing to loosen it and neither did various penetrating fluids, or sharp hammer taps. After 13 years and a thousand engine hours, the prop was firmly attached and the cutlass bearing needed replacement. I suppose a real prop removing tool (based on a "C clamp" design) would have been smarter than gear pullers, but their was a line cutter on the shaft between the prop and strut limiting the placement for such a tool. My solution was to hire an expert boat mechanic. He too struggled but had a more effective vocabulary than I. Now that the prop is off (and bearing replaced), what suggestions are there to better facilitate future propellor removal? I thought about teflon tape on the tapered shaft but then thought again. I have a tube of Mercury prop shaft grease from my outboard. I've pulled that prop twice over it's 15 year life- but its a spline fit, not tapered fit, so I question if the grease helped at all. Anyone have thoughts or should I just hope the mechanic is available 5-10 years from now? Also, I'm thinking of leaving the line cutter off- it was just a 4-5 inch razor disk that seemed like it would be no match for a lobster trap. That way, a good prop tool could be used in the future. Any thoughts on line cutters?
One way to avoid this problem is to pull the propeller every time you paint the bottom.
I used a steering wheel puller and it came out after some work.
I bought the puller from  Harbour Freight.
I use Lana-Cote ( from West Marine $13.00) for this type of application and all other bolts and nuts that need to be possible to remove in the future.
