Autopilot and turning radius
raptor
I had a Raymarine EV-200 installed last year on my 1988 Catalina 36 and it feels like I have lost about 20 - 25 degrees of turning radius. The guy who installed it confirmed that the stroke distance limits the rudder, though he was not sure how much.
The boat starts with such a great turning radius that it is not a show stopper, but I miss the extra radius when I am pulling into my slip.  Has anyone else installed this unit and have you had the same issue? Any way to resolve it?
Aaron
Aaron
Guilford, CT
1988 Catalina 36 "Raptor"
GMatthesen
I installed a Raymarine below deck autohelm which is in the Mainsheet, and may also be on this site. Someone else wrote a similar story after mine, but I dont recall if he addressed the issue of limiting rudder  excursion.
 I have a Mk1 1987 and needed to install blocks to limit rudder movement to prevent over extending the ram in either direction. Since I did the installation before the boat hit the water with me as the owner, I will never know what Im missing, if much at all.
  Look up by my name or the boat name
Gary Matthesen
"Holiday"
1987 #50646
Oyster Bay Long Island NY
Rockman's picture
Rockman
I had the same on mine. I lost that extreme rudder angle that enabled me to pivot the boat in almost it's own length.
Sent from my Power_2 using Tapatalk
I wrote the most recent article in the Mainsheet and yes my EV200 did limit turning by ~ 10 degrees.  It is a balance of torque vs stroke.  I haven't missed the extra steering
Les
EUREKA's picture
EUREKA
Hi,
I have ia B&G autopilot with an hidraulic ram below deck, and yes since the installation, the radius is reduced. This happens with all autopilot with Rams.  It is very important to ensure that piston movement is limited by the rudder end-stops and not by the Ram end- stops.
imhave added additional parts, laminated to the hull in order to limit the rudder before the piston arrived to its end.
Best regards!
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Home port Barcelona (Spain).
