Yes, the counter in the head DOES continue in one piece underneath the cabinets to the left. Very inconvenient when trying to remove the countertop without dismantling the whole boat.
As you were...
As you were...
Theme by Zymphonies
hahaha (you're not talking from experience Jason huh?) :D
... And the darn nav table, behind the power panel is about 3 inches thick if you need to cut a hole for additional cables!!.... ;)
And speaking of drilling holes.... This yesterday's local news should make us all feel better:
[SIZE="4"][B][URL="http://seattletimes.com/html/localnews/2023153507_apxferryleak.html"]Oops. Workers drill hole in Washington ferry hull[/URL][/B][/SIZE]
Maintenance workers accidentally drilled a hole through the hull of the Washington state ferry Walla Walla causing a leak.
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
North Puget Sound, WA
