Hi, all.
When I moved to South Florida from Atlanta last year, I added a prop shaft zinc. It corroded away and fell off the shaft after less than a month. My diver added a couple of new ones, but they also corroded away rapidly. The standard assumption is that the zinc is sacrificing for other boats in the marina through the AC ground wire, so I added a galvanic isolator. (See other thread on that subject.) However, the zincs STILL kept corroding away at an abnormally high rate and we replaced them again. When I asked him what they looked like, he said they were "shiny and corroded" which usually indicates stray current leak somewhere, i.e. not just the typical corrosion pattern from protecting other boats in the marina.
So, the diver brought in his half-cell corrosion meter/tester, which I had read about in Nigel Calder's famous book "Boatowner's Mechanical and Electrical Manual". The diver took a stab at the problem, but wasn't able to pinpoint it, so he let me borrow his book, which came with the tester (ProMarine). At first I couldn't understand it, but after a while I started to "get it" and see its potential....so I bought one through West Marine.
Using the tester, reading Calder and the tester manual, and tinkering (and I managed to do all this without shocking myself :-)), I discovered that the problem was in the AC ammeter and/or reverse polarity indicator, which had been connected to the AC (green) ground bus. (See attached picture. The white wires look a bit yellow.)
The manual says that it is ok to connect white to ground bus for high-resistance reverse polarity indicators, but NOT for low-resistance reverse polarity indicators, since for any significant AC circuit, the AC white (neutral) is only supposed to connect to AC ground back on shore...far back on shore.
Before unhooking the white wires from the ground bus, the increase from hull potential was about +200 millivolts on the test meter. After I unhooked the reverse polarity indicator and the ammeter whites from the AC ground bus, the corrosion meter read exactly hull potential (about -1.0 volt)....which means that the zinc is fully protecting the in-water metals, even over-protecting, i.e. I would be better off to remove one of the zincs.
Last weekend, I had the boat out at anchor at Elliott Key and dove to check the zincs. They are both completely intact and are a dull grey color, and it's been about a month since I did the rewiring....so I think I've found/fixed the stray current problem.
Now I have a new problem: I have no AC ammeter and worse, no reverse polarity indicator.
I'm wondering if I can simply hook the AC ammeter back up but just not ground it to the AC ground bus. I did it for a few seconds and it works, but I'm too chicken to try it long-term. Need a good marine electrician to tell me what to do next...
...but at least the case of the disappearing zincs is solved. :-)
Ben Ethridge
1984 MK1 Hull# 263
Ben,
In your picture it looks like there is a 10 or 12 guage green jumper from the A/C grounding bus to the post beside the meter and that post looks like it is connected to the A/C neutral bus. If this is the case, remove that jumper! Unlike your home A/C system, the A/C neutral bus and the A/C grounding bus should not be connected on the boat. This is done at the shore power box on land. Hope this helps
Tom & Janis Grover
C36 #0949
SR/WK, M25XP
Midland, ON
Maybe I didn't make it clear, but I took the pic BEFORE I made the fix, i.e. before I removed the jumper you speak of, so I think all is ok in that regard.
The pic maybe helpful to others who have the same panel, as I assume this was done at the factory or per factory spec way back then. That seems to be what the corrosion meter manual is implying.
Ben Ethridge
1984 MK1 Hull# 263
My mistake, I thought the picture was taken after the fact. As you note, that was likely the cause of your dissappearing zincs.
Tom & Janis Grover
C36 #0949
SR/WK, M25XP
Midland, ON
[QUOTE=benethridge;17120]The standard assumption is that the zinc is sacrificing for other boats in the marina through the AC ground wire... [/QUOTE]
When zincs are depleting rapidly, the very first place to look is aboard the boat in question. In my experience, the source of the problem is usually found there, far more often than not.
Clean bottoms are FastBottoms!
Yes, that's a better assumption. :-) We did rule that out before I installed the galvanic isolator.
Ben Ethridge
1984 MK1 Hull# 263
