Fuel pump filter
William Miller
Fuel pump filter
Has any one changed the filter in the fuel pump? If so did you have to bleed the system or could you just turn on the electric fuel pump till its full
Capt. Sam's picture
Capt. Sam
I just changed the fine mesh filter in the canister fastened to the aft starboard side of the engine. I dont' know if I would have had to bleed the line, but I bled it as a matter of course, when I started the engine. Engine ran fine with no issues. Bleeding is very easy on my m35, so I do it any time I change any of the three filters.
Capt. Sam Murphy
1994 Catalina 36, Hull 1327
Shoal draft, two cabin model.
Panama City, Florida
Maine Sail
This may help..
[B][URL="http://www.pbase.com/mainecruising/facet_fuel_pump_filter"]Changing A Facet Fuel Pump Filter (LINK)[/URL][/B]
William Miller
Thanks for the reply mine is before the Racor and since I have had the boat for 7 years it will get replaced
StephenK's picture
StephenK
If you have a Racor as the primary fuel filter and a secondary on the engine, do you really need the fuel pump filter? Why not remove it?
Stephen Kruse
Kruse Control #1428
1995 C-36 MKII SR/WK
Lake Lanier, Ga.
One shouldn't rely on the filter in the pump.
[url]http://c34.org/bbs/index.php/topic,5078.msg32616.html#msg32616[/url]
