Stainless steel brackets for cockpit table attachment.
SailorJo
We have recently upgraded the angleguard on our Mk 1 C36 for a Navpod. The outer diameter of the new tubing is 1 1/4", so we need larger brackets to attach the table back onto the angleguard. Does anyone know where we can get these brackets?
Owner of a Mk 1 C36 Hull # 379 commissioned December 1984.
Fin keel, standard rigging.
Boat is based in Nanaimo, B.C., Canada, where you will find one of the finest cruising areas in the world.
Did the same mod last year on our Mk1, and had the same question.
After hunting around (without much diligence, I'll admit) for the larger brackets, I found I was able to just re-use the old ones by bending them a little. They don't quite meet up with the wooden piece on the table, but with some longer screws and some washers for spacers I was able to reattach them.
