Does anyone know a source for the opening Lewmar Portlights lens on a 1987 Catalina 36? My lens are crazed and I thought I had seen a source for ordering these as well as the inside trim.
Bob Gore hull 692
Bob Gore hull 692
Copyright © 2023, Catalina 36/375 International Association
Theme by Zymphonies
Bob,
Lewmar sells the replacement lens and gasket. If you just want the lens, a plastics shop can cut you a new lens if you give them the old one as a pattern.
However, for the same amount of time investment, albeit more cost, you can replace the opening portlights with the new Lewmar model of opening portlights. The new model has the added advantage that it doesn't leak when it rains.
There is a thread, "leaking Lewmars" in the technical forum with more details if you are interested.
Dave
Dave
Ballena 1995 Mk II #1445
