Kubota Equivalents
Universal M-25 is a Kubota Block D850
Universal M-25XP is a Block D950
Universal M-25XPB is a Block D1005-D
Universal M-30 is a Block D1101 & D1102
Universal M4-30 is a Block Y850
Universal M-35, M-35A is a Block V1200
Universal M-35B is block V1305
Our Universal engines are marinized versions of the Kubota tractor engine. For instance, the D950 engine (M25XP) is in the B7100 and B7200 Kubota tractors. The M35 engine (V1200) is in the B2150 and B9200 Kubota tractors, the M35B (V1305) is in the B2710.
M35 Thermostat:
180 Degree, Kubota #15531-73010
Gasket, Kubota #16851-73270
M35 Circulating Pump:
Pump: Kubota #16251-73034
Gasket: Kubota #16239-73430
M35 Injectors:
Kubota #700065209
Links:
Kubuta, How to find serial number
Kubota parts online, Tractorsmart.com
Engine Distributors, Inc (good source for Kubota parts)
Lanealoha
Thanks.  I replaced a water
Thanks.  I replaced a water pump with one I purchased from a Kubota parts supplier.  $35 with a thermostat compared to over $500 from Catalina direct.  I need those margins in my life!
My question is...is there a difference in the parts used for tractors vs. marine use in terms of corrosion resistance or special coatings etc.?  Because I'm looking at sourcing more parts and the tractor supplier parts are just loads less expensive.  Starter, new glow plugs maybe even a rebuild kit seems all reasonable vs a new engine.  Just thinking preventatively.....
Thanks, Dave
