Prop Shaft
Shaft Length:
M25: 1" x 57.5", 1/4" keyway with standard taper
M35: 1" x 53", 1/4" keyway with standard taper
Length is approximate. Measure your shaft to be sure. MkII shafts (M35 engine) are shorter due to increased engine length (one more cylinder!).
Shaft Thread Size:
3/4 x 10
EUREKA's picture
EUREKA
MK I shaft length
Dear all,
I need to replace the original bronze  shaft of my C36 (Hull) 1122, with M35 engine and ZF 10 gearbox. I'm the only owner since new, so all transmission parts are original.
we added a Sigma drive coupler, so the advantage of the new SS shaft is that no Key sit is needed.
does anybody knows the approximative lenthg? Boat is in the water and it will great help if we know the measure in advance. We prefer to be in the safe side, so better longer than shorter, as without the need of a Key sit, we can cut it, to the precise measure.
Thanks in advance!
