You are hereTechnical / Important Notices
Important Notices
Autoprop Issues Product Recall
Brunton's Propellers is initiating a product recall, as a precautionary measure, based on customer reports and in-house technical inspection.
Information Bulletin from BP regarding Diesel Fuel Storage
Click the attachment below for an information bulletin from BP regarding the storage life of diesel fuel.
Universal Service Bulletin - No Starter Motor Activation
Westerbeke/Universal Service Bulletin #213
April 13, 1994
Reports have been received from the field from Universal propulsion engine owners concerning the starter motor on their Universal engine not activating when the start button in the instrument panel is depressed. A clicking noise only is produced by the solenoid on the starter.
Investigation has found that this is the result of a voltage loss at the "S" terminal on the starter solenoid. Voltage is supplied to the starter solenoid when the starter button in the instrument panel is depressed.
Early MkI Lazarette Bulkhead Flexing
Catalina Yachts Engineering Bulletin #15
April 8, 1983
It has come to our attention that the lazzarette bulkhead in some Catalina 36's may not be properly fastened to the deck. Improper fastening may allow the bulkhead to flex when the rudder is turned hard to port or starboard and the stop post on the radial wheel contacts the stopper blocks bonded to the deck.
